I reverter back to the stock maf and connector, I tested the stock MAF to find
-0.06v at the signal waire KOEO, I inspected the sensor fillaments. the tallest one has a bubble in the coating so I tested for continuity from filament pole to pole on the sensor and found non, however the shorter filament has continuity from pole to pole, I tested for resistance and got 0.026 on the shorter filament and nothing on the taller one. I am guesing the bubbling effect in the coating on the taller sensor fillament was due to overheat and burn of the fillament it's self.
I happen to have another stock maf laying on the shelf, I installed that as well and tested at the signal wire, again -0.06v KOEO, I took the second stock maf out and inspected.
Lo and behold after testing both short and tall sensor fillaments for continuity and resistance I discovered the tall sensor fillament was defective on this maf as well, it had come off of one of the poles (the same tall maf fillament as the last stock maf which had an issue, although this one was not burned as the last was).
After some very very delicate saldering using very small silver salder, I managed to re attach the tall maf sensor fillament to the pole, I retested for continuity and resistance, both short and tall maf sensor thermastor fillaments have continuity pole to pole and both test resistance out between 0.024 < 0.026 ohms
I installed the now newly repaired stock maf into the intake and tested out at a perfect 0.70v KOEO
the ECU is no longer in limp home (safe) mode, unfortunatelywhen I start the engine it now revs to 2000RPMs for a few moments goes to die down to idle but instead dies completely.
I thought possible it might be something to do with the avenir injectors working with a p10 ECU except that I realized I replaced the fuel rail from a 95 P10 including the injectors so now I am not sure what it might be.
The only code I get now is DTC 34 knock sensor but I think I broke the holder to secure it during the engine swap.
So besides that I am stuck.
Possibly a fuel inj. issue, ect... Any Ideas?
