1 - 20 of 31 Posts
Searched and didn't find anything so figured this might be good to post...
http://www.sportcompactcarweb.com/tech/0506scc_handling_cornering/
The new correct link...
http://www.modified.com/tech/0506_sccp_making_it_stick_part_1/index.html
There's actually 7 'parts' to this, each one getting much more in-depth. This one is pretty basic, but still a good read...
Edit: All articles written by Mike Kojima. Although Red Lion of Altimas.net/Nissanclub.com took the time to copy down articles 2-4 as they are not on the web to read from SCC's (Sport Compact Club) website.
Discussion Starter · #2 ·
I'd read them all but if you don't feel like reading much, at least read part 3.
Makes me wonder what the ideal drop, in terms of handling, for the g20 is.
Pining for "DMSentra"
ZaRPGfreak said:
i've linked these, i'm posting them in word, and making a small bible out of them. mike kojima, you may not read this, but i love you.
I'll second that too. I have some questions about the building of my B11 that I'm watching for solutions too.
I am just awed lately by the amount of extreme knowledge I've been finding on the net. It's pretty much all coming from G.net and SR20 boards. For that I say... :bowdown: :bowdown: :bowdown:
this is one of the best therds ever and i thank all you guys that put this together i have learned alot just by reading it all
Discussion Starter · #12 ·
Sticky... Sticky... Sticky...
>_>
<_<
Come on, "Making it stick" should be a sticky!
*rimshot*
This should definitely be a sticky, i think i;m goin to steal it and be a hero on another forum I'm on LoL
very useful info, gonna buy that sway bar asap :)
i dont see how having increased preassure in front tyres compared to back decreases understeer though?
i would have thought increase preassure in back, causing less grip causing them to slide out faster, thus having lower preassure in front causing it to turn tighter and decrease understeer.
other than that, great spot on info that everyone wanting to turn better should read.
yup more air in front does not allow any (well actually, a lot less) sidewall flex that causes understeer.
I have some shitty all weather shit tires and when they are low on air in front and i canyon carve i can littery hear and feel the sidewall flex like a mother Fer making me understeer a bit to the outside :(
Discussion Starter · #20 · (Edited)
Eh, it's more like, if the fronts were properly inflated so there's not any sidewall flex, but the rears were overinflated, going beyond the ideal contact patch, that'd create oversteer, since the rear would slide out easier. Same reversed. If the rears were at the ideal contact patch by virtue of the right inflation, but the fronts weren't either too much or too little, the fronts would be sloppy, and boom, understeer.
Although yeah, (touge w00t!), like auto-x it's best to bump up the tire pressure a bit so you don't roll over onto the sidewalls.
Tire pressure is a big part of it too, but it's a pain in the ass. Gauging how much heat will cause the psi to rise, finding a good balance of how much psi in the fronts and rears given your suspension, then repeated testing.
1 - 20 of 31 Posts
