1 - 1 of 1 Posts
Somehow my original post got deleted.
1. Driver side power window - makes a grinding/whining noise at certain positions and needs to be manually pushed. Already had to solder the amp/switch.
2. Tach jumps around then eventually stops at max rpm.
3. Have high beams on drivers side headlight, but no low beams. Have replaced the harness and bulb still no change.
4. Need to replace the AC Compressor.
5. Rear stock speakers do not work.
6. Rear o2 Sensor needs to be replaced.
If anyone knows what could be wrong with that headlight issue or possibly the rear speakers. Also currently trying to locate parts for the rest.
1 - 1 of 1 Posts
