Me to, thanksbigger brakes always look better to me. nice
Yea A34 but the 12.6" which I think starts in 03 I think, I don't think all A34 have the 12.6"Nice! What setup? A34?
Im pretty sure you have to inlarge the spindle mounting ear holes to 14mm on those 350z dual pistons as well IIRC other than that they both use the same rotors 320 × 28.0 (12.60 × 1.102).Very nice! 07' up 350z dual pistons will bolt right up without modification if you ever want too.
The only "modification" you have to do is drill the spindle mounting ears out to 14mm (9/16") I personally used a 9/16" HSS bit with that cutting wax shown in the picture it took all of about 30 seconds per hole.so this bolts right up? what mods are necessary?
...very sexy btw
You only run into that issue when you use RWD brake setup's on FWD Nissan/Infiniti, if you stick with FWD brakes the calipers are spaced correctly so that you do not have to cut your rotors which makes them a tiny bit smaller but most of all you avoid the hassle all together....Yep, 14mm on the 350z setup. I used a 9/16" also. we trashed the 14mm bit drilling 4 bolt front hubs to 5 bolt.... Also did you turn the rotors down? we had to for the 350z calipers.
You might have overlooked it cause its in bold and in a larger than normal font size but your the answer you were probably looking for is in the very first post.sorry but i dont like how people just start throwing numbers out 320mm,296mm,350z shit at a certain point it becomes so confusing that when you are go and try to mod the brakes you dont remenber or dont know what the size was.
other then that sick work
Are rhe rears coming off an A34 04-^ as well?Thanks Brother though I like them next i'll be doing the rears.
Yes granted a few things change over as I expect they will.Are rhe rears coming off an A34 04-^ as well?
