Could be that your oil control rings are dirty and gummed up which can allow oil past the piston. A 24 hour piston soak or engine cleaning product could help free the oil control rings. If your PCV valve and Oxygen sensor have never been replaced you might wanna just replace them, if your o2 sensor is bad it can make your car run very rich which would dilute your crankcase oil with fuel causing oil to get burned easily.
