hello friends,
so my car failed smog, then i worked on a bunch of things, then i waited a year, and then it failed again. i want to know what else i should do.
it is a 1995 manual g20t with 294000 miles. it runs wonderfully. it is smooth, quick, and rev-happy like any healthy g20 should be. the engine, intake, and exhaust are completely stock and original.
here is what happened:
1. i didn't have to smog my car for over seven years because of where i lived
2. december 2016
car failed smog, no surprise
3. december 2016
- completely revamped egr system: removed, cleaned, and tested egr valve; removed and tested egr bpt valve; fixed broken hose on bottom of bpt; diagnosed and replaced faulty egr solenoid; tested egr functionality using factory service manual procedure; no more egr check engine light.
- replaced both oxygen sensors with new oem sensors.
- replaced crappy copper spark plugs with oem ngk platinums. (woops i meant to use platinum last time)
- cleaned maf and tested with multimeter using factory service manual procedure.
- reset timing to 15 degrees. (it was at 13 somehow)
- cleaned k&n air filter with their kit.
- didn't replace cap and rotor, i replaced them in 2015-16 with oem.
4. all of 2017: engineering school ate my life and my g20 sat in the garage unregistered while i biked everywhere. (sorry beautiful friend)
5. december 2017
g20 failed smog again. (worse this time)
6. ???????
what should i look at? i don't know what to work on or replace. the only things i can think of are the catalytic converter being worn out, or a leaky injector, or a vacuum leak.
someone suggested having a shop figure out for me what is causing the high numbers. that would be the first time i ever let a shop touch this car.
thanks for your suggestions
2. december 2016
3. december 2016
5. december 2017
6. ???????
