1 - 13 of 13 Posts
What do you all think of this setup...
Fidanza LW FW
JWT Pressure Plate
B15 disk
I just need to get the PP and B15 disk...
any other suggestions?
Jason,
I already the Fidanza Flywheel all I needed for that was the friction plate, which is on its way.
I plan on boosting in the next 6-9 months, my clutch is slipping now though. So this is why I would like to do the upgrade during my Christmas break.
Would it be unrealistic to say I would like to do this for about $300. All I need is the PP and the Disk.
CarloSR said:
How much boost you'll run ?
Not much... around 300ish.
Is the stiff pedal due to the pressure plate? I have P10 so I am not looking for a stiff clutch pedal. I prefer a medium pedal.
Will my Fidanza LW FW throw a CEL?
I just need to know what PP and disk to get and use for now with my NA setup.
I have driven the ACT XP with the 6 puck disc (my friends 91 SE-R) and that is absolutely ridiculous. Way to extreme, hence the name exterme pressure plate. The ACT HD/PP and the 01 SE disc offers the perfect balance, not to soft or to hard. The JWT PP is way to soft, even the stock PP feels firmer. I stand by the ACT HD/PP and 01 disc. I have had it for over 25k with no problems or slippage, and still grabs as good as it did 2 years ago.
Discussion Starter #11
That sounds good... about $200 for the PP, but the 01 SE Disc, is that the B15 clutch disc?
ACT PP will stretch your clutch cable and may need adjustments.... interested in what you are going to do as well. Also take a look at capclutch.com my buddy with a det p11 has been running and is very happy.
1 - 13 of 13 Posts
