I got a 01 g20 and i just got the stock fog lights but i don't have the stock switch.
anyone know how i can hook these lights up?
i don't want to buy the stock switch...i just want them wired up so that they will turn on when my lights are on too.
any help??
have you tried splitting off the headlight wires yet? make sure you know which is positive and what is negative.
Do yourself a big favor....buy the stock switch and relay
The switch for the steering column is a plug and play, you just need to get the appropriate relay as well
Part Number 25540-0L700 for the steering column switch (im guessing $50 or so) try www.infinitipartsusa.com for the best pricing, send them an email with that part number.
Ill get the relay part number tomorrow, its dark right now. The fogs are already pre-wired and should have pigtails right there for the lights to plug into. This is the same for the stock switch. Takes all of 30 min to install.
Yeh get the switch....then check g20style.com for the rewiring or something so that the fogs come on without the headlights.
I don't know if just buying the switch will allow you to do that???
