looking for a can opener
sr20ve's only came auto. I think it's still possible but not recommend because they are heavily tuned for the use of auto trans. The best bet and easiest thing is to use a JWT ecu. That way you can tell them your exact setup and they will build you own accordingly
You cant use the ECU anyway, you have a 2002. You would have to rewire/alter your harness to a B14 Sentra harness and run their ECU.
BTW: VVL pulls HARD after it engages... :) Im running the stock computer, but then I have a 1993 NX
IIRC you can use the stock ECU as long as its a pre-99 model, correct me if i'm wrong :-\ .
Rob
The VE ecu is OBD1 type. Your 02 Primera is OBD2. You will need to d a lot of rewiring of your harness to get it to hook up. Best option would be to get your DE ecu remapped to handle the bigger injectors on the VE and fit a set of Greedy switches to activate the cams...
Rob
No you cannot, the harness is different
The RR DE ECU cannot be remapped. My DE computer can handle the 333cc injectors, I just cant tune it, thats why I have an SAFC piggyback to go to the dyno with and tune the car. You can use a Greddy MSS, or MSD 8969 (what I have) to activate the vvl.
p10 guru
nope. obd1
