Discussion Starter · #2 ·
Check engine light has came on after 2 days of driving and have not yet had the chance to have it plugged in to see diagnosis
O2 sensors went bad after about 110k. Starter also went about same time. Other than that good. Regular wear/tear included new shocks/struts at 115k and replaced most of exhaust at same time. Runs great.
I would do the 100,000 tune up...
Spark plugs and cables
Distributor o-ring, valve cover gaskets
thermostat, water pump, and belts
motor mounts are usually shot at 100k
rear calipers are most likely frozen
fuel filter
You should look into the IACV coolant line bypass, this will save you from the dreaded p0505.
