1 - 7 of 7 Posts
It is just the standard hamburger of that era. You can snag one from a 92 or earlier sentra. In 93 they rounded off some of the sharp corners.
Yes, from p10 is something like metallic with clear coat or something like it. From p11 is ultrabright plastic, hehe
Thanks, Colin. I was actually using a picture of the back of your gray and red P10 to try to figure out placement of badges and stuff.
Manuel, I might PM you about this, actually. I recently bought a set of Nissan stuff off someone and discovered that the rear Nissan badge looks more like someone took the plastic emblem off a grille and shaved off the pegs that hold it in. I asked the seller, and he told me that the item was sold to him as a rear badge as well, that he didn't know about it.
Aps, anyway the curvature of the front and the rear badge are slightly differents, you cann´t fix one rear badge in the front grille, and you can´t fix the front badge in the trunk. Well, you can, of course, but not will be a perfect work.
Primera badge is about 7/8" in from the left edge, and 7/8" up from the taillamp. I don't know if that is 100% accurate, but thats what I been using the last several times. I think my badges have been on like 5 different trunklids in the last 2 years or so, I keep changing them out. Nissan badge is also 7/8" up from the bottom, in the center, and if you got a 2.0eGT or other trim emblem/sticker that spaceing works as well on the right side. I just use some 1" blue painters tape and cut it up with the papercutter so things are even and square.
*edit* Thats all for the P10, I'm not sure on the P11, never done it but my sig looks right.
Discussion Starter · #7 ·
I'm definitely NOT using the 2.0 emblem I got, I don't even remember what it says - SRI? - something like that. But I'd just feel lame throwing a 4WD P10 on a FWD that needs some help. Thanks so much though, dude. Still have yet to find a Nissan rear badge; got some free time tomorrow, so maybe I'll hit up a junkyard.
1 - 7 of 7 Posts
