The check engine light does not come on, nor does the indicator for when I am in overdrive. The majority of my lights come on, can someone point me in the right direction to get this fixed? Thanks! I checked the fuses and nothing seems out of whack, however several of the fuses are not listed on the panel.
i would suggest taking apart your cluster and checking the light bulb.
yup
If the other lights come on, it can't be a fuse issue... could be wires or bulbs... You'll have to pull your gauge cluster apart and look around, look for burnt spots or light smells...
Some of the fuses you see that are not listed are spare fuses, and the extra fuse spots are for options that your car possibly didn't come with... ;)
Thank you for the responses, hopefully I can figure this out quickly as it is annoying and effects my ability to pass inspections in delaware.=)
