Pining for "DMSentra"
Just dropped the engine on the ground by disconnecting everything and lifting the front of the car with the engine hoist, loose the wheels, then lowering the whole thing and setting the engine/trans on blocks, taking off the mounts and lifting the car back up. Now that it's free I see no hooks or anything simple to lift the engine with. Did G's not have any lift points, or am I missing yet another obvious method? :zoinks:
Used to own a P10
I put a chain around the header and a chain around the intake manifold.
I use an engine leveler/chain setup and bolt the brackets to the alternator bracket hole on the front of the engine (pulley side) and the bolt hole near the throttle body linkage on the rear of the engine (distributor side).
