1 - 2 of 2 Posts
thought this would be a good bit of news that would aid the G community.
according to the following links, a non-rr valvecover will fit a rr head, but not the other way around.
obviously u run into the small issues of the vacuum/oil tubes on the right of the valve covers not matching up and a PCV valve that might interfere with the plastic piece on the left side of the engine(and needing new hose), all minor stuff.
http://www.sr20forum.com/showpost.php?p=1431450&postcount=65
"so u did absolutely no work to make the de valve cover fit th RR?"
http://www.sr20forum.com/showpost.php?p=1444536&postcount=76
This should make it much easier for us rocker guys who want to buy a 2nd valve cover, with rr covers being so hard to find.
dont forget to install the oil catch can on the front of the motor, the RR VC has better baffles in there than the nonRR VC, hence they dont need it. But if your putting the nonRR VC on there, best to add in that catch can.
1 - 2 of 2 Posts
