1 - 12 of 12 Posts
Administrator
my 95 g20 is leakin oil by the front right corner wheel, and im not sure where to begin to look, any ideas any body?
well....
keep in mind that it could be from just about anywhere but that is just where it happened to travel... I'd suggest first cleaning up the engine compartment area and then taking a flashlight to see if you can see a source from the top.. then you gotta jack it up and look from under the car..
Some common area's for a leak are:
a) Oil pressure sending unit or switch (near the oil drain plug if I remember correctly)
b) ifyou just broke your right front motor mount -- you 'lost your load' and it can look like an oil leak
c) possible valve cover gasket?
...anyway, that is the 1st three places I would look/check!
good Luck!
Administrator
i got it fixxed, the threads on the oil cap were stripped so i bought a new one, thnx :)
You are one lucky puck! My problem before was crank engine oil seal. So, while at it..., I replaced the crank and the H2O pulley's with the UR ;)
Might be having that problem right now. Anybody got pics on where the OPSwitch is? Searched the site and couldn't find pix. Help me out.
1 - 12 of 12 Posts
