1 - 8 of 8 Posts
I have a u13 bluebird, which oxygen sensor do I get for the it, the regular one for the infiniti g20 dont fit,this one looks smaller. Im talking about the one on the exhaust manifold
from what i remember it has the same amount of wires but the clip was different. i didnt even cut the wires though. The wires have connectors on the end. You can pry them out with a flat head. It's easy.. you should be able to figure it out
Wh not just swap over your 02 bung from your usdm and get a z32 twin turb 02 sensor. It's longer and plugs right into your stock harness.
z31 o2 must be used with a bb ecu..all other ecu's use the stock o2/z32 tt o2..both plug right in..that bung can be unscrewed and a stock bung will fit into the hole
I assume the BB and Z31 use a Titania sensor then ??
My P10 uses one and they work completely differently from Zirconia sensors. Zirconia sensors produce voltage whereas Titania sensors alter resistance.
P10 G20 rear sensors are Titania btw...
1 - 8 of 8 Posts
