Day 2 - May 27 - May 30 2016
So this past Friday I decide I need to get things rolling on this car. So I rolled it on to the lift Friday night before leaving work.
I gave the front bumper away a while back. There was need for the bumper else where so off it went, but I do have a white one for this car now.
You may notice in the pic there is cable that is hanging down. That is the AT shift cable. Yes this car was an automatic.
Some pictures of the inside before going forward.
1) Auto to Manual swap
First thing to change was the pedal arrangement....2 pedal to 3 pedal...I only have a couple pics, but the firewall on the p10 doesnt have an imprint of where the clutch pedal goes. Only really location indicators was the cut out on the sound deadening and the 1 bolt that holds the top part of the clutch pedal. So what I did was knock out the stud on the clutch pedal. Once I did that, I was able to mount the clutch pedal to the upper bolt. Completing that, I put a punch through the bolt holes on the clutch pedal and marked where to drill. The main hole for the clutch cable, I used a hole saw. IIRC 1" one and then used an air grinder to shape the hole just right.
Another problem that comes up is that the oem MT P10 has a spacer welded to the firewall and it spaces the pedal from the firewall. Luckily I kept all the parts even that spacer when I did my hydro conversion on my KH3 P10. So I went ahead and instead of what the factory did, I welded the spacer to the pedal. If you dont have this part, dont fret, you can use washers or use some nuts to space the pedal. It does need to be done to clear the cable coming from the firewall.
Factory Stud
Stud removed
Spacer welded and the stud rewelded
Then I switched out the brake pedal....
and viola~! 3 pedals
After getting that done, I decided to I should work on the engine harness. I removed the old one and installed another AT harness (FYI you remove the A/C evaporator). Yes an AT harness not an MT one. Life will be much easier with the AT harness back in the car as all you really need to change on it to work on the manual are the trans switches (setup for AT) and the TPS sensor. If you go with the MT harness, you will need to swap plugs on the driver side frame rail too. If not others as well (ie inside the cabin). So I learned that keeping the same harness that went with the originally car is the way to go.
New Harness
The engine that is going in is the 20v that shows up from time to time in my other build threads. So I'm installing a JWT ECU that has a built in rpm switch. Although a bit pricey, JWT can use their N2O module to activate the cams and you run another pin from the ecu to the solenoid. I have no clue what they have it set at and its fixed. Meaning I cannot change the cam change over on my own. Anyway, this part I wasted time on....I had a hell of a time depinning a pin from the cut up harness. I could not get any of the pins to release even with a pin removal tool...I finally got one but I swear I had to pull on it so hard that I thought it would break. Once I got that pin, I ran the switch over wire with the harness.
Next up to bat was removing the shifter. 4 nuts hold the shifter assy on, 2 10mm on the top and 2 12mm underneath. The ones underneath require the removal of the heatshields above the cat. The shifter cable is also bolted the body. 2 10mm are located on the top of the "trans" tunnel roughly around the ECU. Take the bolts out and pry off the cable plate and pull the cable through the hole. I ended up cutting up the cable so I could install just the plate back to cover up the hole. I went ahead and installed P11 linkages from my other/original white car. I did this because the trans I intend to use will be a B15 trans that I had in the other white car. I thought for a while to go ahead and install the other 6 spd trans I have, but for all intensive purposes (money & time) I decided to go with what I had.
So with the shifter in, manual swap was for the most part complete.
I turned my attention to the brakes. The car didnt have any calipers so I went and installed a set of calipers I got from Charles a while back. I also switched out the rotors as they were about the rustiest ones I have seen in a long time. I used the rotors and pads I removed from the KH3 car when I upgraded its brakes last year. After a few pumps of the emergency brake, the rear calipers were ready to go.
I dragged out the 20v and finished up what I needed to do to get it installed....I made a bracket so I could remote mount a VE IACV.
I mounted it close to the "front" of the engine so I could have easy access to the adjustment screw. To mount the IACV I had to modify it slightly....I removed the part with the brown plug and flipped it around. This done so it would be easy to plug in. The other solenoid was already modded for me but it was replaced with a stock DE one. The IACV "intake" or draw portion was rotated so it was pointing towards the TB, but so it wasn't in the way of the brown plug. As seen in the photos, I use a brass 1/4"x 3/8" NPT 90* angle tapped in to the aluminum angle that Charles gave me (thanks Charles). Its important to note that the nipples needs to line up with the correct portion of the IACV. Charles also welded a piece of aluminum on the back side of the plenum so I could tap and the same fitting into the intake. This is the feed to the engine from the IACV. The plenum was also modified by Charles so a N1 TB could be mounted.
If you were following my other threads, this 20v was modified with P11 VE water pipes. This was done so I could use the mechanical FICD (Fast Idle Control Device) on the TB since the standard electric element FICD one from the DE is not installed (and would be a pain to). Hopefully it'll work as I think it will.
I swapped the accessories as they are the ones which are destined for the other white car (ie 20v AC compressor, 20v alternator and '99 G20 P/S pump). I used the Alternator and P/S pump I removed from the KH3 car as I knew they worked. The A/C compressor I ended up picking up from the wrecking yard as the white car's original unit was hopelessly disassembled lol and noisy.
So with the accessories set, I turned to the header. I have a couple headers I could have used, but this one was handy and worked with the VE ports.
I have an ASP, but was saving it for the KH3 car. Impul header is on the black car, I have a 3rd gen hotshot, but needs porting to work on the 20v and it was in shitty shape. There is another header that I have, but the downpipe was hacked up and it was still on that JDM engine. So for now I used this SS auto crap one. It was handy and it fit the VE gasket without work.
Removed the engine from the stand and installed the other white car's flywheel which IIRC is a clutchnet aluminum 11lbs flywheel. I decided I would go with the oem exedy clutch I had on the black car as it was hardly used. For some reason I always forget to install that metal gasket thing that sandwiches between the block and trans... so I removed and installed that stuff twice. Kinda pissed me off as I had the trans on when I noticed I forgot it...
Then in the engine went...
Whatever reason it was a real tight fit. I should have just removed the tps, but I notched the lip a bit instead.
After mounting the engine up, it clears with plenty of space. I stopped taking pics, but I got the rest of the A/C hooked up, radiator installed, clutch cable hooked up, most of the wiring on the engine set up. Still have an ass load of stuff to do.
Maybe next update I'll have it running!
