So, I'm not a skipper anymore
Spent my time at "work" today working on the car. I decided to head out 2hrs than I usually do and get a head start.
Before I left work on Friday, I primered the door hinges. 1st thing I got in, it was just warm enough in the building that I was able to coat it in some Mazda white I had laying around. Later on sprayed on clear on it as well. Here's the final product.
So if you've been following my other builds, you'll probably remember I removed the stock springs/AGXs from the KH3 car a couple weeks ago. So I decided that I did not have an excuse not to get this done :evil:
Started out with the rear, since I am just swapping assemblies, so its actually pretty quick. Its always a pain to remove the back seat, but its a pinch easier with the touring car's 60/40 split seats
Relatively straight forward no surprises. I also decided I should finally install the SS braided lines from Technafit. A couple months ago I attempted it but technafit sent me lines for a totally different car. The fitting would thread, but the seat inside the fitting was inverted from what I needed. It took a few weeks as technafit insisted they sent the right parts so they wanted pics. They finally acknowledged the problem and sent new lines to me, and I've been sitting on them for a while. Anyway went on without a hitch, although I wish they used an angled banjo fitting on the caliper....it would fit much better imo.
Since I had the AGXs out, my curiosity lead me to the FSM as to what oem springs were on this set. I originally got this set in a trade for some Eibach pro kits I had on my other white car. But low on behold, I lucked out and have springs from a MT car, so this will slightly lower the car in the front compared to the AT springs the car had (remember I swapped this car)
The front was a bit more complicated as I wanted to not only replace the shocks & brake lines, but replace the UCAs & tie rod ends as well.
After removing most of the parts...
I had a bit of issues with the cheapo UCAs I had bought. The passenger side's big end was too big. I had to do some massaging to make it fit but I got it to work. I instantly regretted my purchase however. The Driver's side installed without a problem however. Otherwise this portion was also relatively straight forward. When I was originally putting this car together I had swapped out the 3rd links to the 1991-Jan 94 style one so I could use 91-94 brake lines. I don't know if I ever mentioned, but where the brake line attaches to the frame rail is also different on between 91-5/94 and 6/94-96 cars. It is different enough that you need to either modify that little bracket of remove the bracket and replace with the later car. I had gone out to the wrecking yard during the summer to try to get the bracket, but the spot remover bit I had wasn't able to reach the welds. So I gave up. At the end of the day, you can't just swap the third links to use the brake lines, its a little more involved and not really worth the time imo. Anyway, I swapped the car's original thirds back in and the techna-fit lines I ordered were for the later cars so all is well.
After going through the install and problems with the techna-fits, I really wish I had gotten goodridge lines instead. I didn't have a problem with those when installing on the black car and the goodridge lines fit better...anyway next time I know
Since I was working on the front suspension and pretty much had it a part, I also came across some ES swaybar bushings while looking for parts. Decided to install those bad boys as well. The oem bushings have seen much much better days....
The car had a really bad cartoonish boing boing sound when driving over bumps. The Culprit was both end links were completely shot. Seemed like the grease dried out years ago as rust was coming out of a small hole in the boots. I bought end links a while back so on they went.
I ended up replacing the tie rod ends anyway, but surprisingly the ones on the car were still in good shape, although a bit crusty looking lol
Next I decided that should dump the stock exhaust.....so off came the exhaust from my other white car. The exhaust is a VRS 2.5" stainless steel one. It was just hanging off the hangers so it came off the car pretty easy. I usually have the worst luck with exhaust bolts, but on this car all came off with ease.
Stock vs VRS
Exhaust tip
Finally I took the time to swap the door hinges I mentioned earlier. It sucks that you need to remove the fender to do it, but man it is worth swapping the hinges if yours are sagging. Its a great feeling to open the door without it dragging on the clasp!
So with the suspension work, it rides waaaaaaay better. The car controlled, no weird noises and roll has reduced significantly. Definitely worth the effort!
The exhaust, as I remembered, it drones more than I'd like, but it is quieter than when it was on the other car. The other car's catalytic converter was an aftermarket one installed by a local exhaust shop and well, they didn't do a good job welding in the new cat...a few burn through holes in the welded areas and the outlet gasket was leaking. So with the oem cat this car has and a fresh gasket is probably what is making it a bit quieter imo.
Anyway its nice to finally give up the captain's hat!
