If you do this to your own car because you have to then you are a g20 guy....
Anyway, thats how it started. It makes more sense if the window is up and door is closed however. Anyway kinda shitty way to start.
I didn't take many photos coming out, but here is a pic sometime before noon Saturday. Background is the old 20v. Foreground is the replacement long block from Charles.
Decided that I should install a Oil Pressure gauge. So I bought an Autotech Motoring adapter for the oil pressure sensor port. It provides a male BSPT, female BSPT and 2 NPT ports. Made out of stainless, not a bad piece at all. You can see that silver thing is the sending unit for a VDO 150psi gauge.
It was about time to make this engine look the part, so I put on a fresh 20v valve cover. The center panel is from the old 20v's valve cover.
Motor going in...
Things I did.
-Squiggly went in much easier without the Alternator, radiator and crossmember installed. That's for sure.
-Welded some bar on the squiggly so it can use the exhaust hangers from the cat.
-Also cleaned out the iacv, changed the solenoid itself, but still it doesn't really idle with the a/c on.....Not sure exactly why.
-Drilled and tapped another hole on the manifold for the brake booster vacuum line. The 20v manifold one causes too much kinking in the line without having a comically long hose...
-Swapped back to the p10 crossmember. The front engine mount stays are damaged on this block anyway and I figured that the p10 one might fit better with the squiggly and yes there is a smidge more clearance on the p10 member. Stacked tolerances?? I dunno.
-Changed the passenger side steering rack boot/bellows. It was destroyed.
-Added the wiring for the VDO oil gauge.
-Removed the fuel vapor canister.
-Used a 3/4" dayco hose with a 90* in it for the heater hoses this time, works great.
-rewired the VVL solenoid so it actually has 12v power.
-reinstalled the quarter window I removed...
So I need to remove the cat and fix one of the studs. I totally destroyed it. I might try to remove the cat and drill through the flange and add a bolt instead.
Squiggley clearance.
I'm going to see if I can get the windshield changed this week as its not only cracked but also leaking too...
Motor going in...
Things I did.
