There was a P10 clutch cable install thread on the forum that detailed how to install a motorcycle cable lube fitting so you could spray lubricant in the fitting to keep the cable nice and smooth.
Did a new clutch cable about six months ago and it's stiffening up already. Just want a good way to keep it lubed and smooth.
Did a search under clutch cable and looked through most of them for 45 minutes (a LOT of threads) but no luck.
Thanks!
tell if you can and how you did, also were you eventually get it please, casue this is an issues for most p10s I think (atleast it is for me!) thanks.
There's a motorcycle shop in my town (Two Wheel World) that usually has EVERYTHING ... I'm just gonna bring the printout of the package from the tread and show them. :) Then experiment and see if I have room to fit it to the tranny end of the cable so I can lube it regularly without removing the cable from the car. I hate that creaky feel.
