My mate with his p10 is having a prob with first and reverse gears crunching.Can the cable be adjusted manualy or is it self adjusting,as i can't remember any help would be appriecated.
GTUK
There should be an adjustment nut on teh actual cable! If teh adjustment nut doesn't help any, then it is probably stretched out and needs to be replaced.
Yes the cable can be adjusted manually easily from the
engine bay. It is quite common on the P10's for the
cables to become stiff & make the pedal very heavy on
taht sort of age.
