1 - 7 of 7 Posts
The insulators/grommets on my crossmember are dried and crumbly.
Is the dealer the best place to get replacements?
Thanks!
are you talking about the 4 rubber pieces (2 front 2 rear) where the cross member bolts up to the rad support/frame?
lou do you have a part # for me? I'm actually looking for this.
Yep, those are the ones. I buggered up the ones in the rear while remounting the crossmember. I thought I'd replace the fronts while I was there. More importantly, I'm trying to figure out what I'm going to do about the cross threaded rear crossmember bolts. I had some trouble getting the member to line up right and that forced the bolts go in at an angle. I couldn't tell until it was too late because I was tired, wanted to be done and got heavy handed with the impact gun...
1 - 7 of 7 Posts
