Hi.
To all the G owners out there i had just install coliover on my p10 and was wondering is there a better and faster way to make adjustments on the front ( or bypass the third link is in the way) other then taking apart everything. Advice and feedback needed. Thank you
supposedly o2G2o adjusts his teins without taking them off,
but it may only be possible on tein because they have a smaller shock diameter,
but like Kal said, pretty much no, theres little to no space in there,
you mayy be able to undo the bottom mount, unbutton the UCA from the third, expose the coil and adjust like that, but at that time u might as well take it off because ull be able to lock the collars better that way.
