1 - 8 of 8 Posts
Do the P10 have a led flasher relay? the reason im asking is I baught some leds from superbrightleds.com, and they said that I might need an led flasher for the leds because the regular lights use very low power. The flasher will prevent the car from thinking the light is out and dubble flashing. I know theres a flasher in the p11 but is there one in the p10 and where is it located in the car? and if anyone has done this please jump in a spread the info.
so You dont know where the flasher is located???
this site has a flasher that will replace the oem one with one that works with led's
all i need to do is find the turn signal flasher
Thanks !!!!!that diagram helps alot. DO you think Ill have to take out any thing to get to it??
well theres a couple of plastic trim pieces that go around where your knees go when you're sitting down. I haven't taken my dash apart too many times so I cant remember seeing that piece before. Keep in mind this is the diagram for a 94 p10 Im hoping they are in the same spot.
Discussion Starter #8
they should be.
1 - 8 of 8 Posts
