where is the stock alarm box located and where is the fuse for it when i was disconnecting he antenna i shorted the alarm and trunk light is not on either and head unit is not coming on.
i need to reset the alarm or see if the fuse is blown i searched and ffound info on the p10 only
ty
you can find the alarm-cpu on top of the ecu under the dashboard-middle!?
i have the original-alarm kit build in my car and i must fixing it on the ecu!
The fuse is in the power cable of the alarm-unit.
i hope i can help you with these words :shifty:
cu
