P11 auto trans leak need help.
644 Views 1 Reply 2 Participants Last post by  ebinkerd
I have searched the forums and could not find anything like what I am having problems with. Today as I was sitting at the drive thru a lady behind me said I was leaking transmission fluid. Low and behold it was leaking, but at the time it was only dripping. When I left work it was a small puddle under the car and as I was driving it kept leaking fluid until I got to the auto part store to get more fluid. By that time the transmission was having difficulty accelerating every now and then. Bought a few quarts and as I was filling transmission fluid started to leak around the front of the pan. My question is this: do I have just a simple gasket leak or is it something more serious? Right now it is dripping fluid and the whole bottom of the pan is wet with fluid. Also I am getting conflicting answers about what fluid would work for the P11 some say it is just plain Dexron 3 others would say Valvoline Max Life and another group would say only use Matic D.
1 - 2 of 2 Posts
http://www.nicoclub.com/FSM/G20/2000_G20/2000_G20/ma.pdf
Page 11.
Sounds like a simple leaking oil pan gasket. The filter is inside the pan so if you were to drop the pan, replace the filter with a good quality filter, likely infiniti.
1 - 2 of 2 Posts
