Tonight, I was bleeding the air out of the clutch lines and the clutch pedal wasn't returning unless pulled back up by hand. I looked at the slave cylinder and noticed that even if the pedal is pulled back up, the clutch lever arm (on the gearbox) is not returning on its own and pushing the plunger arm back into the slave cylinder. So I stopped to do some research.
My question: Is the plunger on the slave cylinder supposed to return on it's own by a spring somewhere in the transmission/clutch area that I'm missing?
As it is now, the clutch pedal down to the floor doesn't seem to be pushing the plunger on the slave cylinder far enough to disengage the clutch. Either that, or there's something else going on. I can move that lever back and force by hand with no resistance, and it stays wherever I put it.
This is a recently rebuilt 5 Speed with a new clutch, flywheel, TOB, Slave/Master Cyl's, etc on SR20VET motor.
Any help appreciated. Thanks.
