1 - 16 of 16 Posts
The Emo Kid.
I was wondering, is there a front sway bar upgrade for the p11? is it worth it?i searched around, but searching fsb or front sway bar comes up with rear sways, and front strut tower bars...
any ideas?
UM... ok DAMN!!!! This is your captain speaking we might experience a slight bit of turbolence then crash!
If you increase the rear spring rate then it should balance out a larger front sway bar.
Just say no...
Not worth it on a FWD plow...
It's been discussed, search for it. Basically we have a fwd car, so we want to get rid of understeer, we do this by increasing the rear sway. If you were beef up the front sway, you would be right back to where you started, with loads of understeer. Maybe you could make one smaller, or take it off all together.
I've thought of taking it off, but it's a pain to take off. I'll give it a shot at one of the autoX meets this season. No front sway.
Gmac
There are Front Sway bars for the P11. I agree, I would recommend highly against it.
Front Strut Tower bar, rear sway bar, and a rear strut tower bar will be good.
If the front end is too tight and still, .... you slip a little and you become an instant curb plower. haha
:shock: :scream:
Not with my G...no curbage allowed.
Seriously, I just installed my new Addco rear sway bar...and I love the way it handles now. I see no need to add a bigger front bar at all.
NEXT UP...time for some coil-overs! :bigdevil:
:shock: :scream:
I have a rear sway bar as well. I don't have problems either.
I was talking about adding a front sway bar would cause the car to be extremely stiff. An would then become a curb plow. ;)
I knew what you meant...if I am going to plow a curb, I want to do it backwards, not forward. So no upgraded front sway bar... :naughty:
A stiffer front sway bar would decrease body roll. An increase in rear spring rate would counteract any increased tendency towards understeer.
true but you would have to fab the rear sway then. Cause everyone designed for the car is made to counteract the stock front swaybar. And then of course the rear spring rate, would could all be done. But difficult.
Gmac
1 - 16 of 16 Posts
