I'm troubleshooting a no spark condition on my -99 Primera . Im testing sparks with a screwdriver connected to - while cranking the motor.
I've now dismounted the ignition system all the way into the ignition coil, but still no spark. I've measured up the coil with my multimeter, but I dont know what the normal values are. These are the resistances I've measured:
Between tabs about 1 ohm
Between spring and iron core: HI
Between spring and tabs about 12kohms
The tabs are measured without cables connected.
I cant find out if these values are indicating fault or not. Ive figured out that the part is called cm1t-216a , but I cant find a datasheet on it.
Ive checked all the fuses in the box besides the battery, all are good.
Please help
Please help
