Here is your chance to own a unique, 1/1 set of ericdd P11 quad projector headlights in jdm xenon dual glass headlight housings.
-Inside each headlight housing is (2) e55 projectors retrofitted, one bi-xenon and one single xenon, wrapped in a carbon fiber shroud.
-The corners are cleared and have LED lights, simply plug into your corner socket.
-4 HID lights and 4 slim Xentec ballasts
There are a few LED lights on one side that go on and off, see picture. Not really noticeable unless you are right next to the car. The carbon fiber shroud, even with its great craftsmanship, is showing some wear close to the projectors which could be due to heat. It is not largely noticeable, but I did want to disclose such info. The inside of the glass could use a wipe down but not ultimately needed. If you wanted to paint the inner part then it would be a good time to clean the inside. Again, not too noticeable but worth mentioning. There are no lower tabs connecting the duals to corner lights, and one of the upper tabs to the corner is broken (I have the tab for repair). Both tabs on each headlight to mount the duals are perfectly intact. White residue on top of duals near hood closing points will be cleaned up, its plasti dip overspray.
The duals will not include wiring, this is because I wouldn't want to send wiring that is not soldered and had been previously used. It's best to get a new set of wiring for a fresh install.
I had been planning on putting these up for sale months ago as I had enacted some changes with the car and now that I'm getting ready to paint the car this is a great time to sell. These are fully functional and work great.
Link to build thread which may have some answers to any questions: http://www.g20.net/forum/showthread.php?105011-Custom-JDM-Quad-projector-retrofit-project
$300 shipped with 4 bulbs and 4 ballasts. This weekend only. This includes tracking, insurance, proper packing (lots of bubble wrap).
