1 - 18 of 18 Posts
ok i know that the 1999 G20 came with LSD is it viscus or mechanical? does it hold good power or not? is it Just the G20T that has the LSD or do all P11s have LSD?
i am looking tobuy a P11 but i only want one with LSD and Tranny strong enough to hold 350-400hp comfortably...
p10 guru
listen to trbobrk. thats the strongest stock trans. also the b15 trans. if you want the strongest possible, throw an aftermarket lsd into it
ohhh ok thanks. well in that case limeted slip would take the power it depends on how much touque youll be putting through it limited slip usually does not handle much tourque wether its front whel drive or rear wheel. best bet look to see if there is an air locker for it w/ a computer control unit. (similar to modern traction controls)
1 - 18 of 18 Posts
