41 - 60 of 81 Posts
Theres a kh3 like mine that has the high beam tinted yellow. It looks sick. I was maybe thinking of tinting mine. What u think?
The brackets bolt in where your stock tow hooks are... You shouldn't need to buy bolts.
well i just mounted my ballast and saw it for myself you don't have to cut it if you put the ballast over the tow hook, but the bracket for the ballast doesn't align with all 3 holes so you can only use the 2 bottom bolts. it left mine a little wobbly so I'm still going have to use a zip tie or something. theres pics of it on the 1st post
i bought a set of jdm duals without the corners i didn't find the info out but i take it you have to have jdm corners to fit properly?
Discussion Starter · #54 ·
If I wanted it to mount securely cause I like knowing taht shits mounted right and is not gonna vibrate and possibly damage the balast due to vibration and possibly shorten the life of it I had to cut the to tow hook or else it would be mounted wrong.
Discussion Starter · #55 ·
IIRC cause its been a while the tow hook will block the balast bracket from lining up correctly, thats why I cut it so that it lined up.
I'm gonna have to look tomorrow at how I mounted the brackets....definitely didn't cut my USDM tow hook either...
41 - 60 of 81 Posts
