1 - 15 of 15 Posts
Hey guys, I am wondering if the wheels off the P11 will fit the P10 perfectly? Whats the offset on those 2 wheels? Thanls
the P10's wheel is +45 and i think the P11 wheels are +45 also. the problem is the rear suspensions between P10 and P11 are different so you may need a lower profile tire in the back when using P11 wheels on the P10.
tmak26b said:
thanks for the info, can you verify?
The P11 wheels fit fine under a P10 with 195-60-15 tires. Or you could go with 205-55-15 for a wider stance. These two sizes will be the closest to the stock 195-65-14 radius of the P10.
tmak26b said:
I thought the P10 came with 195/60/14
91-93 G20:195/60/14
93.5-96 G20 and G20t:195/65/14
MR. RYTE said:
91-93 G20:195/60/14
Oops! I didn't see that he had a '93. Yea, then you would want one of the following combos:
195-55-15 or 205-50-15
on the P-11's for your '93.
Discussion Starter #8
You guys are right. I have a 94, it HAS 195/60/14 on the car, but i looked inside the center console. it says 195/65/14 My tires book at work says 195/60/14
6'5 290lbs in a G20 said:
...can I put 205/55/14-do they make it and will it fit ? or just 195s on my 91 rims
I believe they do make that size, but you're probably better off going with 205/55/15 instead. I have that size and I must say it looks nice.;)
hypercarrots said:
did you mean to say 205/55/14?
No. 205/55/15. There may be a handful of tires in the 205/55/14 size, but there are far more tires available in the 205/55/15 size.
wider...
I've got the 195 60 15s on my 93.5 and it works out great... BUT be warned that if you go with wider tires, your winter performance and wet performance won't be as good... if you don't care about that, then go ahead with 205s if you wish...
but he can't put those on 14" rims, which is what he was talking about. he was referring to P10 rims, not the P11 rims.
:surprised Sorry about that. I forgot that he was going to put them on 14" rims. So like I said before, it might be a little tougher but I think that you could find 205/55/14's to put on.
Thanks Hypercarrots.;)
1 - 15 of 15 Posts
