Hey my fellow G20 friends.
Im in search for a 2002 p12 primera 6 speed short shift kit. I stumbled across one in the past where the gear selector located on the gearbox was slightly different causing the shift to be shorter and can’t find it.
Im also looking for another option also, would be cool to see if there is an option to change to a aftermarket short shift kit similar to the ones in the picture. Hondas have such a huge range of aftermarket parts and I see there isn’t much for Nissan.
Would be awesome to find something or even be able to alter the one in the picture to work on the 6 speed gearbox that is in my p10.
Wheel Automotive side marker light Automotive parking light Car Tire
Font Scientific instrument Machine Automotive wheel system Auto part
Font Gadget Communication Device Screenshot Darkness
Here you go, p12 uses same trans. Can’t help with the 2nd option
I use the 2JR with mostly positive results and a weighted shift knob. I will say that I like early Spec-v shifter assemblies the best, because the later 04+ with the reverse lockout is a much taller shift lever, and my hand was crashing into the radio cubby on shifts with it.
