1 - 13 of 13 Posts
I got my Pacesetter Header today. It looks good to me. I'm gonna have the extra emissions welded, since they make it for all years, and paint soon. I probably won't be able to put it on till next week. I'll keep you posted. pics will be on my site soon.
Glad to hear you finally received it. I just stripped the primaries yesterday and had a local shop weld a full bead around them as well. I will be installing my 'new' one later this week.
why are you welding the primaries. the inside is already welded and the outside is tached?
I've never held one in my own hands, but I was not under the impression that the inside of the flange-to-primary seal was welded at all; I thought it was just the tacks on the outside. Either way, anything that adds strength to the joints will improve durability. I'd also have a local shop weld in a decent flexpipe, too; that joint PS uses sucks.
I think that they leave the outside just tacked so it is able to expand and contract. I heard nothing but problems with changing the joint . but if I even hear a peep out of it I'll have an exhaust shop weld one in. that won't be a problem to change later as long as they have a lift to get under. I'm more concerned with pluging the emissions I don't need and getting a good coat of paint on. I gave the primary to my father to have the bottom emission hole plugged or welded ( he has tools to do at work). and I'm gonna clean the 2nd & 3rd part tommorro so I can paint that. when I get the primary back I'll do the same. I'll keep you posted.
Reason for welding the primaries: The welds PS does suck ass.
The #1 primary on the first header I received did not even fully extend to the flange and you could see light through it. So I called PS and they sent me another one under warranty.
I received the second header 8 days after the first one and the #1 primary on that one had been machined to close and broke through the weld as well. So instead of dealing with PS and shipping costs, etc. I sanded the primary down and had all four flanges properly welded with a full bead for durability.
I just finished sanding the secondairies down today. Will clean all three pieces tomorrow, paint them and install them. Went with 1500 degree high temp paint. Needs to be cured for 1 hour. Guess I will be taking a one hour drive tomorrow afternoon! ;)
The motor side of the flange on mine is welded completly around and is very clean. the other side is just tached.
Okay, chizneck the spiznecks:
  • $145 - Pacesetter Header
    + 30 - JCWhitney Exhaust Flex Section
    + 30 - No-name 2-to-1 Collector w/Smaller Neck
    +165 - SwainTech White Lightning Header Coating
    $370 - Total Parts Cost.
Welding and shipping aside, this is a very attractive alternative to buying a HS or Stillen header. Sure, it takes more time, and it's a lot of work, but it's not that expensive, and if you know your welder, you know it's done right. I'll sleep better tonight knowing the above prices. ;)
:confused:
Huh? For that, I'd spend $30 more and go buy a new HotShot Gen 5 header and be done with it. Good welds, more power, clean install. More or less plug-n-play install.
Personally, after sanding down, welding, repainting and installing the PS header yesterday, I will never buy a PS header again. The power gains are well worth the price, but the time it takes to get there is not worth it to me.
I must be getting old. It's that 30 something in me that is telling me to not do this again.
Okay, since everybody is poo-poo'ing my previous, take $145 (+S&H) for the header, sand-blast it (doing that by hand is just silly), weld it, and then spend $165 (+S&H) SwainTech it. You still have vastly superior thermal handling and corrosion resistance, and nearly the same strength as the HS design. Not to mention waaaay under-budget.
Maybe the better thermals can make up for the larger midpipe in power gains...:crosseyed...nah. I guess it's still ugly, only white instead of black; most would probably prefer black anyway.
Discussion Starter #11
here is a picture of it painted just crying for me to put it in.
PS header
Not to be a Doubting Thomas, but I really want to know what kind of durability that barbeque paint offers. I want to have updates at every oil change or any significant change in appearance. ;)
Discussion Starter #13
I am very into looks so I'll keep it posted. I have 500 degree paint on my heat shield now and it looks fine, soo 1200 should be great. If not for $150 it's worth a shot . worst case I strip it and use 1500* manifold paint that I just found today( the dayafter I finished painting)
1 - 13 of 13 Posts
