ok for the good of the G20 family I've done some research on this.
First off as has already been discussed liquid metal polish is a good product to use to polish the lenses. I've personally had great results with Brasso.
there is even a company called metal armor polish that has a lense polish. hmm i wonder if they just figured out their metal polish worked on plastic?
http://www.metalarmor.net/examples.htm
there are also quite a few other products out there. here are some examples
http://www.superiorcarcare.net/headlight-lens-care.html
http://www.superiorcarcare.net/plastik-lens-cleaning.html
also using a glaze helps to bring out the shine and fill in the imperfections left in the lense.
http://www.superiorcarcare.net/plastik-lens-glaze.html
The main problem you have is that when you polish plastic you remove the UV protective coating. so the headlights haze quicker. you need to put on a UV plastic sealant.
http://www.superiorcarcare.net/plastik-surface-sealant.html
http://www.detailcity.com/plexus-plastic-cleaner-protectant-polish-13-ounce-aerosol.html
here is another source of car car products
http://www.detailcity.com/car-wax-paint-sealant-products.html
Good Luck!
Dude, your bed is a car..
This is really good info. thanks...
yo sgt dan, iv used tons & tons of stuff the best thing i found is to sand iit a couple times with lik 800 grit up to aout 2000 (or as high as u can get) then rub the HELL outta of it with Meguires PlastiX alot of times untill its crystal clear, then wipe off any residue. then get some clear arcrylic spray paint with a UV inhib in it (crylon) & coat a couple light times, wet sand with 2000 than apply an ohter coat of clear.......sorry to thread jack, buutu i did a write up before but lost it & the pics, but yeah i did it about 6 moiontsh ago & my paaenger light is still crystall clear (the left one is now destroyed)
That is really useful! Hey, does anybody know if I can wet sand my 97' M3 headlight lenses? I know they're plastic, but they have three of those stupid nubby things on em that stick out like a quarter inch. Do those things serve any sort of purpose? Could I sand them off until the lenses are perfectly flat without leaving wierd looking spots?
