1 - 20 of 21 Posts
located on the drivers side, rear quarter, behind the wheel, opposite of the muffler, has multiple tubes connected to the fuel tank.
what is it? what does it do? is it necessary? i cant find it in the FSM
Thats for the drugs playa
does it need to be there?
p10 guru
bhowle said:
Charcoal canister maybe? Def. emissions related.
+1. my first thought exactly
Discussion Starter · #10 ·
is it pressurized? i might need to move it out of the way temporarily to do some work
Discussion Starter · #12 ·
im just wondering in case i remove any of the tubing attached to it. there dont seem to be any electronics connected to it.
well when you remove the tubing you will get fuel on you for sure but when you put it back on put a lil petroleum jelly on it it should seal it good and tight.
Discussion Starter · #15 ·
drilling around it.
It is EVAP related. The gasses from the gas tank go into it and recirculate. It is not pressurized so you wotn have any problems removing it. I believe there are 3 hoses that attach to it and it is bolted with four 12mm bolts. Like I said nothing will happen if you remove it. It is SAFE.
Discussion Starter · #17 ·
^ thank you for that clear explaination.
Discussion Starter · #19 ·
no no not being sarcastic. just thankful your post was very to the point. thanks :)
1 - 20 of 21 Posts
