1PhatG said:
Would polyurethane sway bar bushings be beneficial? I saw that Energy Suspension sells them seperately and all you need to know is the sway bar diameter? Has anyone tried this yet? Also, what other bushings from a Sentra will work with our car. BTW, I have a P10.
Funny you should ask! ; -)
The poly bushings will help a little bit.. depending on how aggresive of a driver you are, you might now need them.. however! They will not get old and cracked like the stock rubber ones can! I would highly recommend them (I'm going to have a set on my G20 soon).
Details on my G20 can be seen at:
http://www.sentra.net/npm/march02/kyle.shtml
As for what other bushings will work on a P10 from the Sentra? If you get a rear set for a B13, all but one bushing will fit (one of the trailing arm bushings, the bushing for the other end of the trailing arm will fit) I have them on my P10 right now.
Also, I've been trying to get ES to make front control arm and multlilink bushings for our cars.. but not sure how long it will be, before they get too it.
