1 - 7 of 7 Posts
i'm going to buy the parts for my exhaust today and i came across something i'm not sure of. i'm going with 2.5in tubing, so i'm using a muffler with a 2.5in inlet diameter. the problem is that i cant find any stainless steel tips from magnaflow with a 2.5in inlet diameter. what can i do?
i was thinking of the welding. im not talking about the end of the tip you would see. thats going to be either 3 or 3.5 i'm wondering how welding is going to work if i am trying to weld a 2.5in to a 2.25in
ok then. so even if the tip's inlet diameter is smaller than the muffler's, it'll be fine. thanks for the help.
La-illaha Il-lallah
The 3" or 4" is the external diameter. Inside the tip sorta slopes into the same diameter as the exhaust... maybe pics help...
Prince of Joy
Right... keep in mind that a 3" tip is only 1/2" diameter bigger than 2-1/2", or less than 1/4" gap between the outside of the outlet pipe and the inside of the tip.
- Greg -
1 - 7 of 7 Posts
