1 - 13 of 13 Posts
Well I have a 95 g,and the power steering don't work, I put a new belt on and still nothing,it doesn't make any noise, but I have no power steering, parking is a pain in the ass. Any suggestions
That happened on my Eagle Talon TSI turbo AWD and it turned out to be a bad pump.
Now maybe the G20 is a different animal?
man i don't know, bump for you though!
Pizdeet kak Trotsky
Black Shadow said:
Does the power steering have a relay or a fuse?
Its mechanical innit ? .......... Might have a electric warning circuit tho :beard:
Got any fluid in it ?
you need a pump if its not making noise the shaft inside is sheared if the pump was ok and there was no fluid youd hear alot of grinding. and on a 95 i would think it had the mechanical system on it because that was befre obd II
You are either out of fluid or the pump has failed, or the pump belt is slipping.
Used to own a P10
95 was OBDII. I am pretty sure all SR20s have a mechanical power steering pump though.
oh well yeah ok i get it now. some cars had obdII before 96 it wasnt required untill 96 right?
Pizdeet kak Trotsky
What is all this bollocks ?
Its a mechanical system :beard:
indeed it is but some things got confused and off topic. eh well anywho yeah im betting that your pumps shot dude
my is making that freaking whine noise, but still full of fluid.
so I got one from the junkyard for free...to cold to install yet.
Pizdeet kak Trotsky
How much are they new or re-con'd anywho ?
1 - 13 of 13 Posts
