1 - 20 of 58 Posts
Please excuse my ignorance as I've been out of the G20 game for a while now, but is this tranny direct bolt on to a VE engine? Also, which is easier to put together...this one or the spec-v 6spd or is there no difference?
This trans is a direct fit on any SR trans, the spec v is a bit more difficult because it will not bolt on directly to an SR engine. The first thing you have to do with a Spec v trans is to source a bell housing from a 20v trans like the one I have so it can bolt on.
Discussion Starter · #9 ·
The trans will bolt up to the engine with no problem, the shifter and cables require some minor modifications so they can work.
The shifter and cables that I had available with this trans are gone.
This sale is for trans only, I also have axle and carrier bracket available.
1 - 20 of 58 Posts
