1 - 1 of 1 Posts
Hi guys.
I have a 1992 JDM Primera P10 and I recently discovered that my clutch bracket was broken so I had to fix it. I took everything out, dashboard, center console off, car was completely naked..
After fixing the issue I put everything back now the car won't crank,, no check engine light when key is on and the ecu LED goes off when I turn the key to on, no spark but fuel is ok coz I wired the pump via ignition so it doesn't use ecu coz one diode blew on the ecu so when I trace it it leads to the pump signal.
Please assist as to what could be the problem.
TIA
1 - 1 of 1 Posts
