1 - 2 of 2 Posts
I want to get new rims for my 1992 primera p10 and want to know what size to get I was thinking 16x8 but don't know if that's a good fitment for it and also idk what offset I should run and what size tyres I should run I'm aiming to make it look more aggressive so any advice would be appreciated
Super Moderator
16x8 is doable with the work and supporting mods.
coilovers will help with spring perch clearance in the back. Shorter upper control arms will help with camber in the front to get the tire to tuck inside. Fender roll or slight stretch will be required almost certainly but how much depends on wheel offset and tired width.
I run 16x8+20 a wheels with a 205/45/16 and it’s about as flush or slightly outside the fender in the rear.
I have also run 16x8+35 and the same 205/45/16 that setup purge the wheel flush and the slight tire stretch fits the tire up insides nicely.
Wheel Tire Automotive parking light Automotive side marker light Car
Tire Wheel Car Automotive parking light Vehicle registration plate
1 - 2 of 2 Posts
