How our g20 members doing?
Had a couple questions as far as maintanace goes on my 02 5sport.
Ive been resolving issues as the car was a "mechanic special" and needed some tlc in areas.
Now ive been driving the car for about 6 months , having repaired most of the original faults restoring it to the beaut she is.
Have a few last things to diagnose and was hoping some other g20 heads could brainstorm with me..
1st off i get a bucking problem from times, looked at spark plugs they were black/ fouled out..changed them and car was running well, knock sensor code when problem returned.
2nd- sometimes @ idle the car temp guage will get to hot and i noticed my radiator fans no longer turn on. changed thermostat and radiator also coolant temp sensor cel is on
3rd- i have a feeling maf/starter/alternator/fuel pump may be the culprits but also did the idle relearn procedure to eliminate the bad idle and it has maintained a health 850rpm
i know this is alot, but if anyone has input from similar experiences pls comment.
Thanks, happy holidays
