1 - 13 of 13 Posts
The Emo Kid.
it looks like the wires it comes with you wont have to use. hopefully the ones off the stock g20 deck will plug directly into the back. if not, then youll have to use the deck plugs off the murano, and the car side of the plugs off the stock deck and jsut splice the wires in matching colors.
The Emo Kid.
also check and see if the murano 6 disc changer will just plug into the g20 deck as is... they ARE setup for disc changers, some just didnt come with it IIRC
it wont work. it has no lcd. doesnt the murano have this central control screen?
^^^ Good point, and are you plugging this into a G20 or a non-Bose Murano? If you're trying to convert to Bose, then it won't work as is. Bose uses a completely different wiring system than regular "non-bose"..
then the simple answer to your question is NO, you can't use that head unit. :(
A bose head unit is not compatible with the non-bose wiring and speakers.
ChicagoG20 said:
:( that sucks
what kind of setup would you recomend to work with a lcd?
i hate this say this but it might actually not be upgradeable. putting a different HU in its place might cause the main LCD in the murano to stop functioning if its not getting an input from the OE HU. this would also mean u cant adjust your heater/fan/ac and whatever other functions the LCD displays.
i dont know muranos tho. there might be a 'kit' to bypass the the LCD or the LCD might not be at all dependant on the HU.
1 - 13 of 13 Posts
