On the panel today I saw the light that said O/D does it mean that it is the Over drive.
The mechanic told me that it means the transmission.
Would some please answer my question.
look at your shift knop on if it is auto and there is press in button that you can push in to go in or out. If the O/D light is on no matter what you do with the button you might have some sort of problem.
if you cant tell whether your overdrive is on or off, and you dont trust your light... take your car out, and see if your shifting 4 gears or 5.
Pizdeet kak Trotsky
5 ? ........ P11 autos have 4 speed boxes....... It shifts to 4th @ 42/43 Mph under light accelaration ...... OD light on means Your "Overdrive is turned off" Ideally teh light should be out (& therefor the function is on) ....... RTFM :beard:
The Emo Kid.
if the light is flashing or wont go off, tranny problems.
if it turns on automatically when you turn the car on, but then can be turned off, thats just weird :p
my bad, i meant 3 or 4
Pizdeet kak Trotsky
Be nice if there was a 5 tho ........ Would smooth things out a treat :nervous:
That & a drain facility on the torque converter .......... Still we can't have everything :(
:beard:
Pizdeet kak Trotsky
2000 G-Twenty-T said:
tranny problems.
I've never had issues with transvestites :p
:beard:
