I know those of you that are banging can help me with this. How did yall get rid of that rattle in the rear deck. That was a lot of consanance in that sentence.
make sure the brake light is securely connected
ʎןןnɟ˙˙ǝdo&#6
take off the rear deck and put some foam inbetween the metal and the top layer to deaden the sound.
Is if fairly easy to take off the rear deck. How dou you get the brake light off. I see the about 3 little plastic clips holding the deck down. Anything else to get the deck off. You have to get into the trunk to undo the brake light, right?
ʎןןnɟ˙˙ǝdo&#6
on a p10, i dont know about p11s, the brake light just needs pulled back and it pops off. you might wanna check the manual on this one because im not sure for the p11s. it'll tell you how to take the whole deck off
I built a new rear deck out of wood and bolted it down...no subs can rattle a huge sheet of 1/2" MDF.
Oh yeah - that third brake light is KILLER!...mine used to jump and rattle against the rear backlite (window) causing serious vibration noise.
