G hoarder
I had a horrendous noise in the rear of my p11, it was the preiodic thumping of a warped rotor combined with the metallic scrape of a hung caliper so i took the car off the road. i finally found the time to tear it apart and i actually had a rotor break! the ring that the pads contact actually seperated from the part of the rotor that contacts the hub. to make matters worse i cant remove the center of the rotor from the hub. :surprised
any suggestions on how to remove a old crappy rotor from a hub i need to reuse? the other side is stuck too. i cant remove either rotor from the hub and neither rotor is reusable.
