i looking for a rear strut mount i only need the passenger side..i hit a bump and one of the damn bolts broke..i noticed when i was checkin the torque on the rstb damn thing kept spinning and spinning..the nut on the bolt that is..
the bolt going through the strut to the rear knuckle right? should be a pretty easy fix if you run the stripped bolt and nut to a hardware store, they should have a bolt and nut to replace what you've got.
Discussion Starter #3 (Edited)
no no..the one that sits on top of the rubber spring seat..the one with 3 bolts..
[/IMG]
number 4 on this picture..
