2002 G20, Auto.
Hi, I've run the gamut trying to repair surging, bucking at low speeds and now I'm on to the "replace the IACV" theory. Yes, I had the computer repaired, thanks, and everything else I've discovered over the past three years. I've just lived with it until I found the Hitachi OEM IACV cheap on eBay from an Infiniti dealer.
My question is how to change it. I can't seem to access the screws well enough. Do I remove the manifold that it is attached to? If so, should I have a gasket or gaskets on hand? Which gaskets? I have to try to prepare so I don't have too much down time.
Thanks guys.
Thanks guys.
